track-bar question
Old 12-09-2006 | 02:10 PM
somis13's Avatar
track-bar question
if the truck is lifted, do you need a longer or shorter track-bar?
mine has the leveling kit, should I just get an adjustable one?
I want the strongest they make, who makes the best?
Old 12-09-2006 | 04:50 PM
TheBigNasty's Avatar
Well, "the best" is in the eye of the beholder. I personally have a Thuren trac-bar and love it, beefy and rebuildable and also not too pricey. But the simple answer for your q is yes....but you can get away with using the stocker, the axle will just be pulled to the drivers side a bit. If you have the money i would get one anyways though because the stockers are junk.
Old 12-11-2006 | 09:45 PM
b.lee's Avatar
Thuren trac-bar is a nice setup for sure.
I will buy one for my lift.
I don't plan on lifting it for a year or two.
Old 12-12-2006 | 12:02 AM
smoke_pedal's Avatar
I am making a trac bar out of chromemoly heims from summit racing. I have had one end of the stock track bar a heim for about a year now, and I am going to make the whole thing, and put heims on each end to allow me to adjust the axle side to side. right now the axle is a little too far to the passenger's side.
Old 12-12-2006 | 08:06 AM
JVDodge's Avatar
You might want to taka a look at the Solid Steel track bar distributed by Source Automotive. It is adjustable, heavy duty and with your year truck it has a retrofit kit to eliminate the ball joint (bushings on both ends of the track bar)
I installed one on my 2001 with a 2" lift and it is nice and solid.
http://www.sourceautomotive.biz/steeringsuspension.htm
Old 12-12-2006 | 10:58 AM
signature600's Avatar
I've got the ThurenFab Bar on mine...it is definitely heavy duty! We'll see how it holds up!
Chris
CTD2001
08-22-2009 10:03 PM
Dinner
05-29-2007 02:02 PM
kwillis-a
01-25-2007 09:10 PM
SWC
40
01-27-2005 08:08 PM
eo1sc
11-17-2004 10:14 PM
Quick Reply: track-bar question
