TPS help please
Old 02-09-2008 | 03:22 PM
Yellow Yota's Avatar
TPS help please
How is it adjusted? What values should I be looking for? This is really starting to **** me off. My truck drives like crap.
Thanks!
Old 02-09-2008 | 03:32 PM
dozer12216's Avatar
How bout little more info on unit. Fill out signature. Is it a GMC or something?
Old 02-09-2008 | 05:26 PM
infidel's Avatar
http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old 02-09-2008 | 08:18 PM
Can't seem to get it to update. It's a 98 12V auto (of course), and it started having problems with the converter locking and unlocking while under very light throttle. As in setting the cruise at any speed above normal lockup speeds. If I go over an overpass, it will lock up and pull good to the top. It will unlock as soon as it doesn't need the fuel, and will go in and out about every 5-10 seconds.
This started the night that I put in the #100 plate and GSK. We also adjusted the idle speed. I'm hoping that we screwed up the TPS when we set the idle.
Thanks for the link. That's what I needed. I'll let you know how it goes.
Old 02-09-2008 | 10:03 PM
Well, i'm not sure about this. I used the link posted above for my info, and I didn't come up with what I'm supposed to.
I had 5.1 volts across the two outboard wires, but only 0.71 between the black and orange with the key on and the harness plugged into the sensor. I pushed out the metal sleeves that come in the holes, and was able to get it to 0.9 volts. Nowhere near the 1.4 to 1.5 volts that I'm shooting for.
I'm going to file the holes out a bit to see if I can increase the number a bit.
If anyone has had a similar situation, I'd really like a call from you.
I'm trying to get it together now!
Thanks,
Chad
(541)501-0437
Old 02-10-2008 | 06:41 AM
TIMMY22's Avatar
you may need a new one if you can't get consistant readings.
Old 02-10-2008 | 03:47 PM
96 Ram man's Avatar
When I put in my 3k gsk kit, my tranny started acting up too. I was told some of that is normal due to the kit changing the amount of movement of the throttle...if I recall that correctly.
John
Old 02-10-2008 | 10:23 PM
My readiings are consistant. They're just lower than they should be.
I just slotted the bolt holes pretty good on the mill, and will throw it in tomorrow afternoon. Hopefully, I will be able to get it to 1.5 volts. Even more, I hope that this is the problem.
I'll let you guys know what happens!
Thanks again for the input.
Chad
Old 02-11-2008 | 10:14 PM
Got it to 1.37 after the mill work. Seems to be nice again!!!
whosdunit
05-17-2014 08:54 AM
SuperiorRam
03-15-2007 03:10 AM
BigBully
09-28-2006 06:54 PM
Dulley4x4
01-04-2006 09:39 PM
IH8MYCAT
02-07-2005 04:53 PM
Quick Reply: TPS help please
