top speed freeway? / sluggish 12 v 1 ton dually
Old 08-09-2016 | 10:04 AM
sanddragon2004's Avatar
Hey guys,
hoping its just in my head. hoping the pros here can give some opinions and guiadance. 96 12v with 215hp p pump nv4500 5 speed 4x4 dually 4:10 gears 225/75/16" tires.
freeway speed at 2000rpm is like 55/60mph. seems sluggish though. I have taken the silencer ring out, it has an aem intake, I can hear the turbo spool sounds healthy nothing abnormal.
truck has 0 mods accept the aem air intake. Would like to wake this thing up.
advice?
Old 08-09-2016 | 11:15 AM
patdaly's Avatar
First thing is to document how much boost and fuel pressure you have.
How long since the fuel filter and pre-filter was changed?
Old 08-09-2016 | 11:26 AM
Great advice.
It could easily just be starving for fuel.
Old 08-09-2016 | 12:44 PM
I was told that the filters all had been changed prior to my taking possession of the truck.
I guess ill be getting some guages going on this bad boy sooner then expected.
Old 08-10-2016 | 08:14 AM
patdaly's Avatar
Doesn't have to be fancy, even temporary boost and pressure gauges will help figure it out.
You need the boost visible from the cabin, but the pressure can be underhood to tell us what we need.
Old 08-10-2016 | 06:09 PM
gorms's Avatar
Fuel pressure....
Should be 17-20ish at idle, 30+ at 2500 rpm no load. If it's low pinch off the rubber return line, gauge should spike over 50 psi. If it does clean filter and pre-filter, consider replacing overflow valve. If it doesn't replace lift pump.
Also consider it may start to around 2500 rpm or earlier stock. 3k rpm kit helps quite a bit with that.
thewished
02-27-2008 08:47 PM
Price_Dog
11-22-2005 01:08 AM
B-rock
05-02-2005 09:46 PM
dealseeker
24
12-18-2002 10:39 AM
dhe9
10-28-2002 04:57 PM
Quick Reply: top speed freeway? / sluggish 12 v 1 ton dually
