Too much Star wheel adj
Adjusted my starwheeel last week to increase fuelling.
When I pulled my 5vr over the week end the engine seemed to act like it was getting too much fuel when starting out and taking a small hill before turbo spooled up.
Don't get any smoke but I think I am going to back the wheel down a few turns, seemed like the engine ran better, with out stumbling. My fuel filter is pretty new so don't think that is the problem.
Anyone else experience this?
i was considering doing this, does anyone have any pics, diagrams, or other info regarging this. I know i can search, but i like the most up to date info about things and searching is generally a exercise in futility for me
![Stick Out Tongue](https://www.dieseltruckresource.com/forums/images/smilies/tongue.gif)
I believe you may have adjusted the wrong way and brought on some turbo lag. The TST #6 under load and with a backed-off afc should give some smoke. As I remember it, the top of star wheel should be moved towards the engine to reduce afc tension for better throttle response.
With TST plates, it is common practice to move afc full forward for full tension release and then start adjusting in tension (opposite of the above) until reaching acceptable smoke level.
Jerry
Jerry
Remember, moving the wheel toward the fire wall stops the fuel rack. Forward increases fuel and smoke. Forward would be top of wheel away from you. Also, it dosen't have to be a lot. A little will go a long way.
..Preston..
..Preston..
Thanks for the replies. I adjusted my star wheel in the right direction, it is now at the top end of the afc housing and is difficult to reach the knurled wheel.
When the Tst #6 was installed I do not think the housing was moved all the way forward though. Guess I could go back and slide it forward. Would that be worthwhile?
In any case I think I will back the wheel down slightly and see if that helps.
Too much smoke means too much unburned fuel. Doesnt this mean it is bad for exhaust gas temps and bad for your engine? I am trying to get better mileage on my 97. I tried turning my starwheel away from the engine to decrease smoke. Will this get me better mileage?
I noticed after I installed new stock injectors I seem to have had more smoke and probably a little worse fuel mileage. The last trip I made I got around 19 mph but this was averaging probably 55 mph with some of it right around 70 mph.
Does anyone have any pointers?
thanks,
Matador
thanks,
Matador
USMC64-70
I had similar results when I turned my star wheel all the way forward. I dont know if altitude makes any difference, but with my star wheel all the way forward, the truck accelerated worse.
It took me several adjustments to find the right place for my star wheel.
It turns out, it was about half way between the stock setting, and full forward.
_________________________________________________
98 2500
There are some pic, diagrams, and directions on how to do this. It is quite easy.
Try posting your question in the 2nd Gen Performance and Accessories section. You should get good response there.
__________________________________________________
matador
Yes, in theory, you are correct.
However, the star wheel only affects PRE-BOOST fueling. The star wheel only affects how much fuel is delivered until the turbo can provide boost.
This is usually a very small amount of time.
Unless your driving around all the time under load and at very low rpms, the amount of time the star wheel actually comes into play is/should be very little.
Rich
98 2500
matador
Rich
So if a person felt he had to much smoke after boost was kicking in where do you find the adjustment for this and is it safe to play around with this. Do you have a link to good info on this?
thanks,
Matador
matador
Rich
Rich
thanks,
Matador
Smoke after the turbo has spooled is a result of not enough air.
First, you should fill in your signature to give us an idea of what kind of truck, trans and mods you have.
Then, in order to keep this thread on topic, you should place your question in a new post in this section.
However, to quickly answer your question, smoke after the turbo has spooled up, is a result of too much fuel and not enough air.
Its a little difficult to help with this until we know more about your truck.
Thanks
Rich.
Thanks
Rich.
jjrightmire1973
11-20-2008 08:20 AM
jdr160
01-12-2008 07:05 AM
