tire size change VS speedo calibration
Old 07-23-2006 | 12:49 AM
GCSS's Avatar
I went from 215 75r16 to 235 75r16
The new tires are a tad taller.
the truck is a 1998 12 valve 5spd. Can Chrysler go into the computer and re-calibrate the speedo??
THANKS
GCSS
Old 07-23-2006 | 09:30 PM
out_drsman's Avatar
Speedometer World...
I just changed my VSS gear when I went to larger tires. It is a 5 minute job and the part is only around $30. You can get them
Here
Good luck.
Old 07-23-2006 | 11:01 PM
abarnar1's Avatar
Yes, Chrysler can recalibrate the speedo. That tire size will probably be in their computer. They just plug it up and change it. If that size is not in their computer you need to find the exact diameter of your tire. There is a formula you can plug that diameter into and figure out how many rpm's per mile your tire turns. Then go to Chrysler and they can punch that into their diagnostic computer and recalibrate your speedo. I had mine fixed, it took about 2 minutes and they didn't charge me anything. Not sure where you can find that formula, hopefully someone on here will know it.
DieselBoy20
03-14-2012 01:13 PM
Inferno Ram
06-15-2006 09:23 PM
Leadfoot
02-12-2006 10:28 AM
gadgets
29
11-19-2005 03:07 PM
Old Iron
05-11-2003 02:15 PM
