timming an injector pump
Old 10-08-2013 | 05:30 PM
Roger Arceneaux's Avatar
pump was taken off without engine at tdc or pump being locked. what do I have to do to make sure the pump is in correct timming position?
Old 10-08-2013 | 06:34 PM
patdaly's Avatar
You should be able to rotate pump so the timing plug goes in, then the same with the engine.
Should work just fine.
Just don''t forget to pull both back out before rolling engine over.
And make sure the bore in the gear and the shaft are spotlessly clean!
Old 10-08-2013 | 07:01 PM
infidel's Avatar
http://www.cumminsforum.com/forum/94...ack-stock.html
http://www.cumminsforum.com/forum/94...en-engine.html
drolex
37
09-21-2009 07:01 PM
wvopowered
03-09-2008 06:13 PM
kyle_truck_pull
02-24-2008 10:01 PM
2007 5.9
07-23-2007 07:10 AM
adidasman23
02-07-2007 12:34 PM
