Timing p7100 in Inches
for timing info using an inch dial indicator<br>5.4mm= .212598 in. = 11degrees<br>6.4mm= .251969 in. = 16 degrees<br>so if you use an inch dial and move it to 1/4 in<br>your timing will be at 15.75 degrees btdc
DTR Advertiser
Re:Timing p7100 in Inches
Timing is not fixed on all pumps. Cam lift rates determine the amount of lift each type of pump needs to be advanced/retarded.<br><br>Some pumps need less lift and some need more to get the same degrees of advance/retard.<br><br>I like your idea of converting over to the inch system for use with a "normal" dial indicator though <br><br>Don~
VikingDiesel
04-04-2007 10:44 AM
dutchman
12-31-2006 04:12 PM
1qckdodge
13
08-28-2006 11:35 PM
sleeping dodge
Competition / Pulls / OffRoad
07-08-2006 07:14 AM
