Timing case assembly after KDP attack.
Old 12-08-2010 | 05:25 PM
RAKFIRE's Avatar
Has anyone done one of these and have photo's or video? My case is cracked at the inside bend behind the fan pully. I want to change it because It's the only seal that I haven't replaced and It leaks lie the deep water horizon in the gulf. Or is there anyone in ct that's willing to help for pizza and beerz??? (I work at refinery's and tank farms, they don't like to see rainbows on the ground.)
Old 12-08-2010 | 07:00 PM
infidel's Avatar
Lots of info and links to pictures here> http://www.cumminsforum.com/forum/94...tructions.html
Old 12-08-2010 | 10:37 PM
rebal's Avatar
if your case is cracked your in for a hand full of work. last one I did was about 10-12 hrs
Old 12-09-2010 | 09:46 AM
Intercool's Avatar
yea ive been there and done that. it was cracked in the same place you are describing, but the leak was just enough to be annoying. I will be honest it is not an easy job and will take you all of 10 hours with the right tools. make sure to get a genuine cummins case to put back in. i have seen some pretty flimsy copy cat cases for cheap...dont buy one of them!
Old 12-09-2010 | 10:27 AM
Diesel_Power_2's Avatar
Wondering what the case is made of? If it is aluminum why not TIG weld the thing?
Old 12-09-2010 | 10:42 AM
infidel's Avatar
I have only used the cam gear removal method on the last five case replacement jobs.
It cuts the time easily in half and isn't all that difficult.
Cummins has been using this method exclusively for at least ten years.
The saved work well pays for the investment in a good gear puller.
Smokin96_12v
10-12-2009 07:39 AM
aksparkey01
10-31-2007 11:45 AM
Abbynormal
06-09-2006 09:01 PM
Dr. Evil
19
04-17-2006 12:35 PM
Dusty Ratcliff
21
03-15-2006 07:11 PM
Quick Reply: Timing case assembly after KDP attack.
