Timing
go to www.godgeram.org...in the diesel tech section....u need a few tools...gear puller, dial gauge, something to turn bar the engine...a special adapter for the dial indicator....and whatever else i forgot...i think i got it all
Andrew
basically ur gonna be disconnecting the pump from the engine by pulling a gear out and ur gonna turn the engine over slighly like an inch or somehting and put the gear back in....thats in anut shell
Andrew
Originally posted by MasseyMan1089
How do you change the timing? Can someone post a link to a thread or a site? Im going to do it when I get my 3000gsk installed. 16.5 sound good?
Instructions here> http://dodgeram.info/tsb/1994/18-10-94a.htm
So by advancing my timing to 16.5, it will make it run better and knock louder? I like that. haha Does anyone have the special tools, especially the dial indicator with the adapters or whatever on it that I can borrow? I'd appreciate it alot! As far as the other tools, I can make do I think. We have alot of mechanics tools and what not. Anything out of the ordinary to be used? besides the dial indicator?
Just a word of caution!
You guys with 215 pumps already have some advance built in. . . be careful about going past 16 degrees if you have a virgin head gasket/bolts. Especially if you're running quite a bit of boost and/or have the stock injectors, even more so if you've got some miles on it.
Advancing timing is popular, but be aware of the potential drawbacks: http://dodgeram.org/tech/dsl/FAQ/timing.htm
Vaughn
Vaughn
if i take it to a local diesel place ..what is the labour code on advancing timing...i mean how many labour hours is it/cost?...2 hours?? cause if im missign almost all the tools i might as well give it to aguy to do for 200$ then spend 300 on all the tools ...get it done to 16 degrees once and for all....what about for my setup with no gsks...will i still benefit from 16? or should i get 14?
hey guys out of curiosity it was mentioned alot of times that timign can slip over time...HOW does it actually slip?? i mean everything is held in place mechanically with gears...im having trouble visualizing it...help me out..i mean could it be possible my timing is at like 9 right now???
Andrew
Andrew
The gear that adjusts the timing is just on a tapered shaft with no keyway that's why it slips. If it couldn't move you couldn't adjust the timing. That's why it's extemely important that the shaft and gear are spotless before torqueing it down.
You shouldn't have to pay over $200 to have the timing bumped, problem is finding a place to do it. Many places won't do it because it's against smog laws to set anywhere but at the spec on the engine data plate.
Unfortunately Masseyman, NO. Some have done a "poor man's" method by marking the crank damper, pulling the pump gear, inching the engine back about 1/3" then reinstalling. Not a safe thing to do, goof it up and you have no idea where you're at. Best to get the tool or pay someone to do it.
Vaughn
Vaughn
alright i found someone that will bump my timing!! gentleman at a local coffee shop liked the truck and came up to talk to me turns out he's a diesel mech...i told him about my timing envy and he said he'll do it next week...its a private shop so he says he doesnt care ... so guys i need to know what i should request while im there with him ...16?? 17??? 18??...my setup is in my sig...160 pump...everything stock....no springs but WILL get them in th spring(4k gsks) i dont tow...its a daily driver
for guys who had their timing bumped let me know what u think the best timing would be for me based on your experience
Andrew
Andrew
I've run my '95s from 14 to 20 and like 16.5 the best, any more and starting is harder.
Make sure whoever is doing your timing is using the dial indicator method, otherwise go elsewhere. No matter how much they swear up and down they have a method that works they are basically just guessing where the timing lands.
