Timing
Old 03-08-2005 | 04:46 PM
Hoyt's Avatar
Timing
This may already be covered but....
I am thinking about advancing the timing on the ol Cummins.
16-16.5* is what i want, but with 160,000 on her, will this increase in
engine pressure possibly cause some seals or something else to begin leaking?
There is no leaking (relatively speaking, it is a diesel) right now on the truck
Just curious if this is even a possible problem
Thanks
Hoyt
Old 03-08-2005 | 04:58 PM
signature600's Avatar
I advanced mine at 240K miles...no problems after 40K more, and lots of towing.
I don't think that without A TON on mods that you could have any problem that wasn't already gonna happen.
Good Luck, and Advance that timing,
Chris
Old 03-09-2005 | 06:46 PM
gwhammy's Avatar
Ya can see my mods on the 97, it was stock until 235,000 miles. The timing really helps.
Old 03-10-2005 | 12:59 AM
Vaughn MacKenzie's Avatar
Hoyt, what injectors do you have? That will play into the equation. You don't want to advance more than 0.5* to 1.0* beyond stock with stock injectors. With 300s or 370s then yes maybe up to 16.5-17* on a stock head & gasket since you don't have a 215 pump.
Your miles aren't an issue, mine is OK at 372,000. Vaughn
Old 03-10-2005 | 01:00 PM
got...DIESEL?'s Avatar
19* on 300's......no problems that I know of, but I DO have the little pump. starts and runs at 0* like it does at 35*......but not quite like it does at 60*
Just did my dad's stocker '95 to 16.5 and he's all smiles. Just after we timed it I took my brother wife for a ride in mine, and I broke a shaft. He towed me back home and said he saw quite a bit more responsiveness and less pedal than before under a load. He too has the little pump though.
Chris
Old 03-11-2005 | 07:59 AM
Hoyt's Avatar
Vaughn, I still have stock injectors , but if I advance my timing, I will also throw in some new injectors. thanks for the replys, now all I need is for the wife to allow it
Old 03-11-2005 | 08:58 AM
gunracer1's Avatar
i have mine at a little bit more than 16 on my 97, i did my wifes to 17. both 215 pump trucks, mine has 370's and her is stock other than a#10 plate. it made a big differance on her truck when i bumped the timing, not as much of a differance on mine. i plan to bump mine to 17 or a bit more also to see how mine likes it. and you can get a idea on the miles in the sig.
Old 03-11-2005 | 09:52 AM
MY WORLD's Avatar
timing
Hoyt,
The timing should work,OK. If you worry, you can replace your studs one at a time to better seal the head.
I'm moving mine to 17 in a couple of weeks Let the good hot times roll!!!!
WAYNE
Old 03-11-2005 | 11:34 PM
cumminsdriver635's Avatar
Will advancing my timing to 16.5* help lower EGT's any? If so how much?
Eric
Old 03-12-2005 | 06:08 AM
bulthisl's Avatar
Yup it will
And it depends on what plate you are runnin as to how much.
: Eddie :
Old 03-12-2005 | 08:07 AM
Thanks Eddie! Ive heard that it will, and i plan to advance mine to 16.5 degrees in hopes to loose some EGT's.
Eric
Old 03-12-2005 | 05:38 PM
mr T's Avatar
i got a 95 stocker everything stock what would u guys recommend? 16??.....by the way where are u guys getting it donw or how are u getting these guys to do them to that degree? cause anything beyoned 14.5 is illegal .
Old 03-12-2005 | 07:46 PM
bulthisl's Avatar
I do them and I don't pay no attention to the law.
What is the cops going to do ...pull you over and check yer timing ?
: Eddie :
Old 03-13-2005 | 06:02 AM
mr T's Avatar
i looked into doing the timing bump myself...toughest part is getting that lil adapter for the #1 fuel line for the dial indicator where did u guys get that?.
Old 03-13-2005 | 01:05 PM
MasseyMan1089's Avatar
How do you change the timing? Can someone post a link to a thread or a site? Im going to do it when I get my 3000gsk installed. 16.5 sound good?
Quick Reply: Timing
