Ticking sound from fuel lines on 96?
Old 06-26-2008 | 01:50 AM
Bookshelf's Avatar
If I'm next to the truck on the drivers side, or underneath right at the end of the t case I can hear a ticking sound from the fuel lines, listened with a stethoscope and its definitely coming from them. The pump itself doesn't have noises coming from it though. Noise doesn't vary if its cold or if I have been driving it. Normal or sign of a problem?
Old 06-26-2008 | 05:43 AM
12 flapper's Avatar
Mine ticks, and I figured it was my lift pump I changed my fuel filter and it went away. I don't know if its good or bad though?
Old 06-26-2008 | 06:44 AM
Mainemike100's Avatar
Mine does the same thing, I assume it's normal. Sounds like the relief valve in the pump is opening and closing with every pump stroke and allowing "spurts" of fuel to flow through the return line and make the noise.
Old 06-26-2008 | 07:38 AM
John Faughn's Avatar
Check your fuel pressure , which truck ?
Old 06-26-2008 | 09:32 AM
Gary Emerald's Avatar
all of my 12v's have done it... it's the sound of the lift pump resonating back along the line to the tank.
my red truck quit doing it for about 10 minutes after I installed a new lift pump and then she went right back to her little song
Old 06-26-2008 | 09:59 AM
infidel's Avatar
Both my trucks have been doing it for most of their 200k plus lives.
I just live with it.
Old 06-26-2008 | 11:53 AM
crabbelle's Avatar
mine does it, when it stops ill know it went up.
Old 06-26-2008 | 12:31 PM
Bookshelf's Avatar
I figured it was normal for the piston LP/P pump combo, I'm going to check my fuel pressure eventually though, the truck has 391K on it. Thanks.
Old 06-26-2008 | 12:39 PM
wcbcruzer's Avatar
Aren't there two kinds of ticks? One is the normal kind that you can especially hear with a mechanical fuel pressure gauge from inside the cab. The other is a tickity tack tack sound; maybe from a lift pump going bad??
Old 06-26-2008 | 01:22 PM
justme-'s Avatar
All 12v's do it I have been told, and every 2nd gen 12V I have been around has done it. Nothing to worry about.
Old 06-26-2008 | 02:39 PM
2500's Avatar
thanks for the info!!!
Old 06-27-2008 | 07:55 PM
rock mafia's Avatar
My 96 never did it, but my 98 does
1985cucv
04-11-2010 10:42 AM
bws
11-27-2005 03:18 PM
1tuff3500
09-07-2005 11:12 PM
doodah
01-28-2005 03:48 PM
autodealer
12-04-2002 04:46 PM
Quick Reply: Ticking sound from fuel lines on 96?
