"ticking" noise
"ticking" noise
I have been hearing a slight ticking noise coming from my engin. I never noticed it before. To me it sounds like a dead lifter in a 350chevy. Anyone have a guess as to what it could be?
Re:"ticking" noise
My guess is that it is the transfer (lift) pump. See if you can get a mechanic's stethoscope and listen to the pump. Also, listen to the overflow valve on the inside of the injection pump.
If it is the pump, when you replace it, be absolutely certain that you fill it with light oil before you install it, and then again make sure you have diesel running through it before you hook up the outflow line. If you try to prime the pump when it is dry, you will erode the piston and it will start ticking again in a few weeks to months.
If it is the overflow valve, check for a broken checkball spring. That is the spring under the first hex on the assembly.
Location: Alberta Foothills - Power to grow with 6 in a row - XLR8
Re:"ticking" noise
Sorry I don't have an answer for you but I'd also like to know what that ticking noise is. In my case it sounds like it's coming from midway back, driver's side, between cab and box. ?????
Andy
Andy
Re:"ticking" noise
I chased the phantom ticking noise in mine when I first bought it. Replaced lift pump and overflow valve and it still ticks. I've just decided to live with it. On mine it resonates in the fuel tank. If you put your ear up to the tank or take the fuel cap off and listen it is very pronounced and sounds like a check valve checking. Thats probably what it is.
Re:"ticking" noise
[quote author=Eat Beef link=board=16;threadid=22443;start=0#msg210304 date=1069030013]
Andy
[/quote]
My truck sounds the same way. I can not find were its coming from.
Andy
[/quote]
