Throttle sticking
Old 01-05-2011 | 09:33 AM
Onemoparnut's Avatar
Throttle sticking
I am trying to help a friend with a problem with his throttle sticking. He says it only sticks till it warms up then it is fine. The truck is a 97 2500 4x4 ex cab auto. Does anyone have an idea where to start he says he thinks it is in the pump. I am going to look at it tonight and see for myself.
Old 01-05-2011 | 09:50 AM
infidel's Avatar
Most likely just a rusted or gunked up linkage that needs to be cleaned up and lubed.
The throttle cable can also fray and cause sticking but isn't effected by temperature.
Cable and linkages also had a recall that may have never been done.
You can check here, you will need the VIN> http://www.dodge.com/webselfservice/...ilForm(%27R%27)
Old 01-05-2011 | 10:15 AM
Thanks for the info he says he unhooked the linkage at the pump and it seems to be inside the pump but I havent seen it for myself. I am waiting for the vin now.
Old 01-05-2011 | 11:08 AM
I looked up the vin and it says there are 2 recalls that were never done. One for the throttle linkage and the other was for the hood latch.
Old 01-05-2011 | 01:55 PM
torquefan's Avatar
When the pump lever isn't attached to the linkage and the return springs, it has no returnability at all. The lever will also feel more notchy with the engine not running. As mentioned, the common cause is the ball sockets on the linkage rod. Also make sure the return spring hasn't fallen off.
Old 01-06-2011 | 09:35 AM
I didn't even get to look at it the truck is going to the dealer for the 2 recalls on monday and we will see if that fixes it. If it doesnt then i will mess with it. Thanks for the info everyone
Old 01-06-2011 | 10:01 AM
infidel's Avatar
Normal for a 12 valve pump to very stiff if the engine isn't running.
It takes the governor weights to be spinning to loosen up.
doug60
04-19-2005 07:06 PM
smokeyram
11-17-2004 09:43 AM
finallydiesel
06-18-2004 08:42 AM
dublr
11-21-2003 08:30 PM
Quick Reply: Throttle sticking
