Throttle return gizmo
Old 11-22-2006 | 02:04 PM
TIMMY22's Avatar
My throttle return linkage gizmo is getting a little weak. My throttle was getting stuck so I added a small spring to the lever. now the pedal is a little stiff. anyone know a good source for this part?
Old 11-22-2006 | 02:12 PM
TxDiesel007's Avatar
If what you replaced it the actual throttle return spring..
I think some trucks have three or four springs, mine was missing all of them minus one per say.. I know that DC offers a pretty pricey repair kit for the throttle return springs, but what i did was just use a zip tie and stretch out the spring a little more on mine by grabbing it from another coil a little bit lower on the spring and hooking it to the little nub that it connects to from the zip tie..
If all else fails you can go to a hardware store and buy some spring assortment and see which one works, for me it was just a temporary fix, but it has worked much better than i thought...
Rick
Old 11-22-2006 | 08:02 PM
infidel's Avatar
Most 12 valves have two return springs side by side.
I get replacements at the hardware store.
Picture of a single spring in figure 8 here http://dodgeram.info/tsb/recalls/B15.htm
BearKiller
03-25-2007 12:13 PM
360ramcharger
04-27-2006 08:07 AM
DodgeCowboy
12-06-2005 08:57 PM
Battering Ram
50
11-19-2004 10:20 AM
Buzz
01-07-2003 02:25 PM
