Throttle cable connector
Old 03-08-2003 | 09:14 PM
samb097's Avatar
Can someone tell me how to disconnect the throttle cable from the ball on the throttle lever. I have tried prying on it, pulling, etc, but am afraid I may break the connector if I try too hard. This is on a 1995 Cummins. I need to do this to insure the low idle is resting on it's stop. Then measure from the back of the bracket (that the throttle cable is held in) to center of ball and set it to exactly 5.0 inches (126.5 mm) by adjusting the length of 'throttle lever to injection pump lever'. At this point I will check TPS output and it should be 1.0 +/- 0.2 volts. At WOT it should be 2.2 to 2.9 volts higher than at idle position. If it is not correct the 'throttle lever to injection pump lever' can be adj up to +/- 1 mm to to meet voltage requirements. If voltages are not within specs change TPS.<br>The above routine is copied from the Dodge Truck shop manual. Thanks for any help on the connector.<br>Sam.
Old 03-09-2003 | 05:05 PM
Smokee's Avatar
Re:Throttle cable connector
As I recall, you hold the bell crank, slide the cable forward, and pop the connector off.<br>george
Old 03-09-2003 | 08:36 PM
samb097's Avatar
George, I have seen any number of this type connector that comes off as you said, but I can't move it in any direction. Thanks Sam.
Old 03-09-2003 | 10:03 PM
Ray,IN's Avatar
MY '96 linkage was replaced under the recall, and the mechanic just sprayed Liquid wrench on the connectors and use a screwdriver to pop them off the ball fitting. The new ones snapped on easily. The old ones corroded and bound up the linkage, thus the recall.
90firstgen
04-13-2008 05:48 AM
D45
02-17-2008 08:11 PM
Kirk T
09-20-2006 07:19 AM
hellotbone
10-07-2003 06:54 AM
Iron Horse
11-24-2002 10:32 PM
Quick Reply: Throttle cable connector
