Think I need to post again
Going back to my original thread, I am looking for information if anybody is familiar with the recall on the wiring harness needing to be replaced on the older Dodge trucks with tilt I read the hardness wears through and you have do not start problem
And does anyone know if this is a common problem for ignition switch to go bad if this is my problem, trying to get some information before I start tearing the column apart
A 1998 12V truck was only built for 3 months and is it own special wire harness.
They came out with the 1998.5 truck with the 24V after a very short run of 12V.
I have a 1998 12V SRW 3500 QCSB truck myself. It is a very low production truck.
No dealer is going to have that wire harness, even if they wanted to change it for you.
Ok
I guess we're both unusual that we have such a low production truck, but I want to know if that harness wears out and wears through is the question if there is a problem with them
I do not see any Dodge dealer having access to those wires, or wanting to do a recall on them.
Corrosion
