Thermostat housing leak, habitual offender
Old 03-01-2009 | 08:28 AM
Diesel_Dan's Avatar
I have owned this truck for 4 years now and in that time I have had to replace the thermostat housing o-rings at least twice a year and I am really getting sick of it. is this a common problem? I am using cummins parts and I don't know why it keeps on leaking every 4 to 6 months. It drips on the belt and it starts squeeling, that is the most annoying sound and I have to install a new belt for it to stop, it is kinda expensive to buy a belt at least twice a year. Any thoughts on a more permanent cure for this stupid leak.
Old 03-01-2009 | 09:07 AM
infidel's Avatar
First of all make sure there aren't two o-rings against the head instead of one.
Sometimes the old ring will be so smashed and old it looks just like the metal.
Could also be over pressure from a bad radiator cap.
Old 03-01-2009 | 10:07 AM
Iron Pony's Avatar
Or a warped housing. Remove the housing and clean it up. Then place it up against something flat like window glass. If it's warped you will see some gaps. The housing could also be cracked. So look it over real good. JMHO
Old 03-02-2009 | 01:45 PM
Diesel_Dan's Avatar
thanks I will check for an old o ring but I would think that would leak almost immedatly. Mabey I will get a junkyard thermostat housing and see if that will take care of it
Big Swole
71
10-19-2012 06:20 PM
Bookshelf
05-30-2009 01:17 AM
olddodgetrucks
03-18-2009 09:35 PM
B.A.Ram
07-07-2007 12:43 AM
ajpulley
11-06-2006 06:57 AM
Quick Reply: Thermostat housing leak, habitual offender
