Is there a gasket in between the bellhousing and front of NV4500?
DTR's 'Go to Guy'
5.9LD-Engine 5.9L Six Cylinder (Diesel)
420-Flywheel and Torque Converter 5.9L (ETB) Diesel Engine
Notes:
DBB = All Manual Transmissions
DG0 = All Automatic Transmissions
ETB = 5.9L In-Line 6 Cummins Turbo Diesel Engine
ET0 = All 5.9L Turbo Diesel Engines
Item Qty Rqd Part Number Qty Line Engine Trans Description
1 GASKET, Rear Cover
485 6021 1 ET0 DG0
485 6021 1 ET0 DBB
485 6021 1 ET0 DG0
485 6021 1 ET0 DBB
485 6021 1 ET0 DBB
485 6021 1 ET0 DG0
2 HOUSING, Rear Main Seal
463 8817 1 ET0 DG0
463 8817 1 ET0 DBB
463 8817 1 ET0 DG0
463 8817 1 ET0 DBB
3 SEAL, Rear Main Crankshaft
442 9410 1 ET0 DG0
442 9410 1 ET0 DG0
442 9410 1 ET0 DBB
442 9410 1 ET0 DBB
4 PIN, Dowel
442 9678 1 ET0 DBB
442 9678 1 ET0 DG0
442 9678 1 ET0 DBB
442 9678 1 ET0 DG0
5 BOLT, Hex Head
442 9638 1 ET0 DBB
442 9638 1 ET0 DG0
442 9638 1 ET0 DBB
442 9638 1 ET0 DG0
442 9638 1 ET0 DBB
442 9638 1 ET0 DG0
6 ADAPTER, Transmission
487 4537 1 ET0 DG0
487 4537 1 ET0 DBB
487 4537 1 ET0 DBB
487 4537 1 ET0 DG0
487 4537 1 ET0 DBB
487 4537 1 ET0 DG0
7 BOLT, Flywheel Housing
476 1248 8 ET0 DBB
476 1248 1 ET0 DG0
476 1248 8 ET0 DBB
476 1248 8 ET0 DG0
8 COVER, Flywheel Housing
476 1247 1 ET0 DBB
476 1247 1 ET0 DBB
476 1247 1 ET0 DG0
476 1247 1 ET0 DG0
9 BOLT, Hex Head
442 9630 1 ET0 DG0
442 9630 1 ET0 DBB
442 9630 1 ET0 DG0
442 9630 1 ET0 DBB
442 9630 1 ET0 DG0
10 PLUG, Adaptor Plate
442 9248 1 ET0 DG0
442 9248 1 ET0 DBB
442 9248 1 ET0 DBB
442 9248 1 ET0 DG0
442 9248 1 ET0 DBB
442 9248 1 ET0 DG0
11 PLATE, Torque Converter Drive
476 2088 1 ET0 DG0
476 2088 1 ET0 DG0
476 2088 1 ET0 DG0
12 O RING, Transmission Adapter Plug
442 9260 1 ET0 DG0
442 9260 1 ET0 DG0
442 9260 1 ET0 DBB
442 9260 1 ET0 DBB
442 9260 1 ET0 DBB
442 9260 1 ET0 DG0
13 FLYWHEEL
488 2546 1 ET0 DBB
488 2546 1 ET0 DBB
488 2546 1 ET0 DG0
488 2546 1 ET0 DG0
14 GEAR, Ring
442 9903 1 ET0 DBB
442 9903 1 ET0 DG0
442 9903 1 ET0 DBB
442 9903 1 ET0 DBB
442 9903 1 ET0 DG0
442 9903 1 ET0 DG0
15 WASHER, Flat
650 1681 1 ET0 DG0
650 1681 1 ET0 DBB
650 1681 1 ET0 DBB
650 1681 1 ET0 DG0
16 SCREW, Hex Head, M12x1.25x34.00
650 1680 1 ET0 DBB
650 1680 1 ET0 DG0
650 1680 1 ET0 DG0
650 1680 1 ET0 DBB
17 BOLT, Hex Head, .37-24x.55
603 3439 6 EW0 DG0
603 3439 6 ET0 DG0
18 PLATE, Drive Plate Backing
479 8968 1 ET0 DG0
479 8968 1 ET0 DG0
479 8968 1 ET0 DG0
19 52118868 1 ET0 DG0 CONVERTER, Torque
20 SCREW, Cap
442 9522 1 ET0 DBB
442 9522 1 ET0 DG0
442 9522 1 ET0 DG0
442 9522 1 ET0 DBB
21 P CLIP
476 1249 1 ET0 DBB
476 1249 1 ET0 DBB
476 1249 1 ET0 DG0
476 1249 1 ET0 DG0
22 DOWEL, Block To Clutch Housing
442 9068 1 ET0 DBB
442 9068 1 ET0 DG0
442 9068 1 ET0 DBB
442 9068 1 ET0 DG0
442 9068 1 ET0 DBB
442 9068 1 ET0 DG0
Notes:
485 6021 1 ET0 DG0
485 6021 1 ET0 DBB
485 6021 1 ET0 DG0
485 6021 1 ET0 DBB
485 6021 1 ET0 DBB
485 6021 1 ET0 DG0
463 8817 1 ET0 DG0
463 8817 1 ET0 DBB
463 8817 1 ET0 DG0
463 8817 1 ET0 DBB
442 9410 1 ET0 DG0
442 9410 1 ET0 DG0
442 9410 1 ET0 DBB
442 9410 1 ET0 DBB
4 PIN, Dowel
442 9678 1 ET0 DBB
442 9678 1 ET0 DG0
442 9678 1 ET0 DBB
442 9678 1 ET0 DG0
5 BOLT, Hex Head
442 9638 1 ET0 DBB
442 9638 1 ET0 DG0
442 9638 1 ET0 DBB
442 9638 1 ET0 DG0
442 9638 1 ET0 DBB
442 9638 1 ET0 DG0
487 4537 1 ET0 DG0
487 4537 1 ET0 DBB
487 4537 1 ET0 DBB
487 4537 1 ET0 DG0
487 4537 1 ET0 DBB
487 4537 1 ET0 DG0
476 1248 8 ET0 DBB
476 1248 1 ET0 DG0
476 1248 8 ET0 DBB
476 1248 8 ET0 DG0
476 1247 1 ET0 DBB
476 1247 1 ET0 DBB
476 1247 1 ET0 DG0
476 1247 1 ET0 DG0
9 BOLT, Hex Head
442 9630 1 ET0 DG0
442 9630 1 ET0 DBB
442 9630 1 ET0 DG0
442 9630 1 ET0 DBB
442 9630 1 ET0 DG0
442 9248 1 ET0 DG0
442 9248 1 ET0 DBB
442 9248 1 ET0 DBB
442 9248 1 ET0 DG0
442 9248 1 ET0 DBB
442 9248 1 ET0 DG0
476 2088 1 ET0 DG0
476 2088 1 ET0 DG0
476 2088 1 ET0 DG0
442 9260 1 ET0 DG0
442 9260 1 ET0 DG0
442 9260 1 ET0 DBB
442 9260 1 ET0 DBB
442 9260 1 ET0 DBB
442 9260 1 ET0 DG0
13 FLYWHEEL
488 2546 1 ET0 DBB
488 2546 1 ET0 DBB
488 2546 1 ET0 DG0
488 2546 1 ET0 DG0
14 GEAR, Ring
442 9903 1 ET0 DBB
442 9903 1 ET0 DG0
442 9903 1 ET0 DBB
442 9903 1 ET0 DBB
442 9903 1 ET0 DG0
442 9903 1 ET0 DG0
15 WASHER, Flat
650 1681 1 ET0 DG0
650 1681 1 ET0 DBB
650 1681 1 ET0 DBB
650 1681 1 ET0 DG0
650 1680 1 ET0 DBB
650 1680 1 ET0 DG0
650 1680 1 ET0 DG0
650 1680 1 ET0 DBB
603 3439 6 EW0 DG0
603 3439 6 ET0 DG0
479 8968 1 ET0 DG0
479 8968 1 ET0 DG0
479 8968 1 ET0 DG0
20 SCREW, Cap
442 9522 1 ET0 DBB
442 9522 1 ET0 DG0
442 9522 1 ET0 DG0
442 9522 1 ET0 DBB
21 P CLIP
476 1249 1 ET0 DBB
476 1249 1 ET0 DBB
476 1249 1 ET0 DG0
476 1249 1 ET0 DG0
442 9068 1 ET0 DBB
442 9068 1 ET0 DG0
442 9068 1 ET0 DBB
442 9068 1 ET0 DG0
442 9068 1 ET0 DBB
442 9068 1 ET0 DG0
DTR's 'Go to Guy'
Picture is of both an automatic flywheel and torque converter and a clutch flywheel and adapter plate you asked about. Each part has a number by it. Next to that number in the list is a description of the part and below it is the Dodge part number.
vzdude,
I think he means between the bellhousing and the transmission itself.
There are only four bolts that hold the bellhousing to the trans, no gasket. There is a seal in the bearing retainer that the throwout rides on. If it leaks it could leak though the mating surfaces.
vzdude,
I'm not good with clutches.
If its the bearing retainer/input seal it will be leaking syntorq (trans fluid) if you are seeing hydralic fluid that is coming from the clutch master or slave cylinder.
Smell should give it away, Syntorq reeks.
DTR's 'Go to Guy'
Yeah.....after re reading it, I think that's what he's after. Agreed. The only thing to leak at the front of the trans is the input seal. If it was a slave cylinder leaking it would show in the clutch master cylinder resevoir. Also, like said above, the trans fluid has a pretty distinct smell!
Its full and has never moved since I owned the truck.
