Testing overdrive solenoid?
Old 08-28-2007 | 10:31 PM
maxpower's Avatar
Lost overdrive a couple of months ago after hitting a big pothole. I've been driving around at 50 mph/2200 rpm's since.
I simply don't have the money to replace the transmission and that's all anyone around here seems to want to do. Rebuild or replace. Several of the places I've talked to I walked out of when it seemed I knew more about this tranny than they did.
My question is shouldn't there be a way to check the solenoid operation externally? That way I could quickly eliminate any other wiring, charging, batteries, etc. issues. Couldn't I bypass the truck's wiring and supply voltage and ground at highway speed and see if it energizes? If it didn't I would know to go internally, if it did I could look upstream for problems.
Or does anyone know a good and honest tranny tech in the Tampa/St Pete area?
By the way I was having crazy shifting problems last year and thanks to help from this forum I replaced the TPS and all was well again until I hit the pothole. That was the first thing I checked this time and the problem does not seem to be there.
Old 08-29-2007 | 04:57 PM
dieseldemon's Avatar
Hook up a lockup switch to check it if you need the wiring for it let me know and I will post one.
Old 08-29-2007 | 05:58 PM
maxpower's Avatar
I'd love to have the wiring for it. I was going to hook up a mystery switch for it but being an early '96 I assume it would need to be re-flashed. That's why I was curious if I could bypass the PCM and test it directly.
Old 09-01-2007 | 06:37 PM
Trans Lockup Switch Wiring
Sorry it took so long to post these instructions but my srcanner was on the fritz.
Attached Thumbnails Testing overdrive solenoid?-trans-lockup-switch-wiring.jpg
Old 09-02-2007 | 01:09 AM
95ram's Avatar
What year pickup do you have. On my 97 they way I tested the OD solenoid was to ground it out. On mine it's IIRC B21 on the PCM. It's a brown wire.
Old 09-03-2007 | 06:46 PM
maxpower's Avatar
My truck is a '96. Would it have to be reflashed, or is that just for the TC?
I thought I had read somewhere that it was actuated by supplying ground, but I didn't want to make a bad situation worse by poking wires when I don't know what's what.
I'm going to try this tomorrow if I can get to it. First I have to fix three flats on the trailer and one on the truck from someone dumping nails on the interstate.
dodgediesel
04-15-2010 10:00 PM
daystar
02-19-2004 07:21 PM
