Temp. gauge
Old 06-25-2006 | 05:23 PM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Temp. gauge
Ok,my temp. gauge quit working guys. Was working fine and all of a sudden quit.What's going on or is this usually the time they tend to go out?I have 156,000 miles on my truck just to give you a little more info.Thanks yall Cin
Old 06-25-2006 | 10:48 PM
cody@nl'sCTD's Avatar
thermostat
this is most likely the themostat, just needs repplaced. at least thats what went wrong on mine and when i replaced it it seemed to work again. could be something else too so id take all opinions
Old 06-26-2006 | 06:42 AM
Thank you Cody. I also need more advice
Old 06-26-2006 | 02:12 PM
ccmckee's Avatar
Does the guage move at all? When the tstat sticks open it should come up to some temperature at least, usually about 1/2 way to 180*. If it does not move at all then the sending unit is probably dead. It is not fun thing to change out either, it is on the drivers side on the back of the head and it takes a 1 1/16" socket.
Old 06-26-2006 | 02:37 PM
yea I know where it's located. Today it started working again for some reason. I have no clue what's wrong. could I have a loose wire?
Old 06-26-2006 | 06:52 PM
infidel's Avatar
The wire to the sensor comes off easily especially if you have been replacing the the fuel hoses.
Old 06-26-2006 | 10:39 PM
hmmm
well i guess u lucked out there. also nice to fix something and not spend any money
Old 06-27-2006 | 05:56 AM
well i don't think it's fixed still getting the sensor today. Infidel,Thanks for the heads up on the wire.CC, thanks for the advice also.
Old 06-27-2006 | 06:38 AM
DieselDaze's Avatar
Id be interested to hear any updates as Ive recently been seeing issues with my temp gauge.
For me, the temp guage moves up and down quickly.
Too quick to be the T-Stat opening and closing, more like the wire is not making a good contact.
While driving, the gauge will never reach 190, but it never falls below ~160, it bounces around between the two.
Im guessing Im loosing a sending unit or the wire has come lose somewhere.
Be intersted to hear what fixes your issue.
Rich
Old 06-27-2006 | 10:18 AM
12valve's Avatar
Rich
I have ridden in several 98 12valves. And all I know that specific year has problems with the temp gauge..... but the trucks temp is fine!
Old 06-27-2006 | 01:23 PM
I know that my temp is fine. The thing with mine is that it started working again and I know it just didn't fix itself so I went and got my sensor today. DieselDaze, my don't move around quickly,it just goes alittle past 140 and stops.The Service guy told me that sometimes they will go back and forth like the Oil Pressure Sensor does I will keep you all updated.
mar67655
03-21-2009 05:35 AM
DennisT
05-11-2007 08:58 PM
turbox2
02-06-2006 07:44 PM
Bad Ramer Jamer
12-01-2005 02:30 PM
firesine
11-24-2005 10:58 AM
Quick Reply: Temp. gauge
