tamper proof screw
tamper proof screw
Need a little help. I searched on here but could not find what size bolt to replace the screw with. Do I just reuse the tamper screw or what?
I believe they are M6 x 1.0. When you get the bolts out, just take one to a Home Depot, Lowes, or local hardware store that sales individual bolts and match them up. I went with allen head bolts to make removal easier in the future.
Other than the Home Depot stores, thats exactly what I did.
Thanks for the help guys. I did it today, the screw wasnt too bad to get out. Gary you were right, I just left it out and its not leaking, maybe ill put an allen screw in eventually
one truck I had had a stripped bolt hole, so I had to put one up under the injection lines... I used an allen screw and just kept a t-handle ball nose allen tool in the truck for accessing the pump.
all my other trucks, I leave the bolt out under the injection lines. makes pump tweaks that much quicker/easier
lobes hows that lock up switch workin for you? i got the same setup and year truck you have except a plate mod and before i had the plate mod i had a lock up switch and sometimes with it off the tranny would lockup at any mph from 15-50 even after i totally took it off the truck it still did it for a while so im just trying to get some imput if it was the switch or what. bc i really liked the switch it was useful
well the tranny will goin to lockup it self at about 30mph with o/d off or 50 mph in o/d, with the switch i can lock it in 3rd and 4th gear when i want and it stays locked. I like the switch because the converter always seems to unlock at the worst time, like pulling a hill with a trailer which takes you out of the peak torque range
Dusty Ratcliff
05-23-2006 10:05 PM
