Tach Going Crazy
Old 02-15-2011 | 01:38 PM
74dart's Avatar
Tach Going Crazy
My Tach is begining to act funky. It will bounce sometimes 200 rpm and sometimes it will bounce between 2k and 4k. Am I correct in assuming the pickup sensor on the harmonic balancer is the culprit?
Old 02-15-2011 | 04:17 PM
mechmagcn's Avatar
Can't help you with that problem, but I never know when mine is going to work
Old 02-15-2011 | 08:47 PM
bentheir_05's Avatar
if you notice that your amp guage fluctuates with the tach i would almost bet that the crank trigger is the problem. i found that out once when i accidently smashed the trigger wires behind the fan bracket....truck would start and run but no tach and no alt. voltage....... when warm and the intake heater is not cycling it should read a bit over 14 on the guage... i may be wrong but just trying to help.. maybe infedel can help a bit more...
Old 02-16-2011 | 07:47 AM
74dart's Avatar
I know that my amp gauge is working because I keep an eye on it since I lost an alt last month. Mech, does your cruise work when the tach is not. I don't need the tach it is very annoying that everytime the rpms jump it turns off the cruise.
Old 02-16-2011 | 09:03 AM
mechmagcn's Avatar
My cruise works seldom. Sometimes I can play with it and it will work, only to drop out a mile down the road. Never really paid attention if they don't work together.
Old 02-16-2011 | 10:31 AM
infidel's Avatar
If the engine speed sensor was the problem you would have more problems than just the tach. The cruise wouldn't work at all and voltmeter would fluctuate in time with the tach.
I'm thinking the problem might be a poor connection or ground behind the tach itself.
Old 02-16-2011 | 11:49 AM
74dart's Avatar
Every time the tach jumps it kills the cruise.
Old 02-17-2011 | 10:31 AM
infidel's Avatar
What's the voltmeter doing when the tach jumps?
Old 02-17-2011 | 08:04 PM
74dart's Avatar
Nothing. It started doing it last night and I made it a point to look at the voltmeter. It didn't fluctuate once but the tach was jumping by 50 to 100 RPMs. Why would the tach affect the voltmeter?
Old 02-17-2011 | 10:53 PM
cj360trider's Avatar
charging is controlled by the pcm and the pcm uses the crank sensor to tell if the engine is running and therefore charging.....
Old 02-18-2011 | 08:30 PM
74dart's Avatar
The thing is the rpms are not dropping. When the tach fluctuates it is jumping up 500-1000rpms not down.
Old 02-19-2011 | 06:38 PM
that sure sounds like a faulty but not yet failed sensor to me. also check connections at harnesses
silverbullet02
03-15-2007 05:17 AM
Tengu
02-13-2007 08:39 AM
Atlantic4x4
09-08-2006 09:20 AM
rebal
01-27-2005 09:00 AM
Quick Reply: Tach Going Crazy
