Swap: DRW to SRW
Old 03-21-2009 | 09:26 PM
iker42's Avatar
Swap: DRW to SRW
Need some help guys. I have a guy willing to do the swap with me, now I have alot of questions. Heres the break down.
His:
SRW Dana 80
3.54
Discs
Mine:
DRW Dana 80
3.55
Drums
So what all do i need to do to swap?
Switch gears? front axles?
What about the breaks? how hard is that to do?
Thanks for anyone who can help.
Mike
Old 03-21-2009 | 09:35 PM
Cummins Freak's Avatar
gears will be just fine.
Old 03-21-2009 | 09:43 PM
iker42's Avatar
so me switching to a 3.54 and not touching the front axle will not be an issue?
Old 03-21-2009 | 09:56 PM
not if you have the higher gears in the front.
Old 03-22-2009 | 03:15 AM
Tate's Avatar
3.54 and 3.55 gears are the same thing. The gear set has 11 teeth on the pinion, 39 teeth on the ring gear. 39/11 is 3.54545454.... Proper rounding to 3 digits would be 3.55, but if you just cut it off at 3 digits, which is 3.54. They are one in the same.
Old 03-22-2009 | 06:38 AM
98whitelightnin's Avatar
If your swapping I would keep the disks too. You will have to get a new mastercylinder too and maybe a few other things but it will be worth it.
Old 03-22-2009 | 08:37 AM
iker42's Avatar
i am keeping the discs, but i thought i only needed a proportioning valve to make it work?
Old 03-22-2009 | 09:39 AM
crabbelle's Avatar
its cake mike, i had my rear swapped out in a day, that included grinding away the old brackets and installing the new lowering brackets
lawdog800
19
03-31-2011 09:26 AM
lawdog800
06-21-2010 08:08 AM
89dieselkong
04-05-2009 05:20 PM
dragginlx
15
03-09-2007 11:32 AM
Quick Reply: Swap: DRW to SRW
