STUPID DODGE and their front driveshafts....
I don't really need anything other than to rant........ Front U-joint on the front driveshaft was getting loose, so I figured I had better do a pre-emptive strike. Ordered the correct Spicer lifetime joint based upon what was supposed to be in there. Today was slow at work, so I figured, might as well get to it.Got the slimy mess out, cleaned up, and the old joint pressed out, not too bad, or so I thought.
New Joint didn't want to start, huh?
Dig the old joint out of the trash ( caps went everywhere ), reconstruct it as best I can, one set of caps is 1-1/16", other is 1-1/8".
Now, I KNOW this shaft is the original one, I bought the truck off the original owner, I have every scrap of paper since new......
You have to wonder what goes through an Engineers mind when he uses a conversion joint on a production vehicle......
Oh well, if we can keep the snow away for another day, O'Reilleys does show one in stock, grab it tomorrow and get her back together.
Bad thing is is a stupid Precision, the only joint in my truck that isn't genuine Spicer.....want to bet which one I twist off?
There, I feel better, thanks for listening.
And with my luck, I would drop the clutch and launch a shaft.....
Even I learned somthing new...I didn't know they used mis-match caps...I replaced mine as a complete unit,because the centre ball was all smashed up..
Pooter
02-25-2009 08:05 AM
IntakeRacing
10-27-2007 02:40 AM
kas83
09-18-2007 10:06 PM
gatf4
03-10-2005 12:52 AM
