Stripped threads
Stripped threads
Some how I stripped the treads when installing one of my rear oil pan bolts. What's the better option, helicoil, or tap/die? Can this be done without removing the oil pan (again)?
but if you want the same size,then Helicoil is the answer
Helicoils are a very good repair, and easy to install. It is a professional repair and will allow you to keep using all the proper matching bolts instead of needing several different wrenches to remove the pan and having to keep track of which bolt/screw/staple goes in which hole.
corn binder
09-23-2007 07:33 AM
