Strange heat problem
Old 07-23-2009 | 09:20 AM
sgtk911's Avatar
I have a 97 Ram 2500 with 5.9L cummins 5 speed manual. My problem is that when the interior of the cab gets hot every summer I have to replace the clutch position sensor. After that it will start every time until the next summer. The local diesel repair shops and dealers are as perplexed as I am. I would like to know what I can do to fix this once and for all or possibly bypass the sensor all together. Any insight is very much appreciated
Old 07-23-2009 | 09:42 AM
Totallyrad's Avatar
I'm guessing grounding one of the wires in the switch may be the answer but wait a bit before you do. By chance, have you dissected one of the faulty switches to determine if it's worn out or actually failing due to heat?
Old 07-23-2009 | 09:59 AM
sgtk911's Avatar
I have taken the last one apart and seems to work fine on the bench but installed it fails under heat. A new one will last until next summer, then I have to do it again
Old 07-23-2009 | 10:06 AM
Totallyrad's Avatar
Check the mount. Just a guess, but it could be the switch housing is being put under some strain when you tighten the mounting screws. New, this wouldn't be a problem but once it's been heated a bunch of times the plastic could soften and it may deform, causing the contacts to be out of alignment, thus causing the switch to fail.
tswcoaltrain
11-12-2019 09:11 PM
bkrukow
04-29-2011 06:42 PM
dieseldel
03-12-2007 09:50 PM
Mike D
14
07-02-2004 09:17 PM
nancym
08-20-2003 08:40 AM
Quick Reply: Strange heat problem
