strange charging
Old 01-07-2007 | 08:08 AM
ticki2's Avatar
strange charging
About a year ago I put on an external voltage regulator and everything was good till 2 weeks ago . After warm up volts would go up to 14.5 for a while and then cut out . It will keep this up about every 10 to 20 min between cycles , no ryme or reason . Put on a rebuilt alt. and same thing . Put on a new voltage reg. and same thing . Also , when in the charge mod the lights have a pulse , dim slightly then bright , in a defenite rythem . Batteries ar also new and are showing 12.7 with voltmeter , checked seperately. I'm stumped....
Old 01-07-2007 | 08:42 AM
Geico266's Avatar
14.5v is okay for the top end of the charging cycle. 12.7v is great for batteries after charging. What is the worry?
Old 01-07-2007 | 09:06 AM
ticki2's Avatar
When it goes above 14.5 the check engine light comes on , then it will just go down and the needle drops well below 14, plus the light pulse when it is charging high. It use to stay steady just above 14 .
Old 01-07-2007 | 09:11 AM
Geico266's Avatar
Double check your ground wire connections. A loose connection can cause "over charging", but 14.5 is borgerline, but should not be a problem.
Old 01-07-2007 | 09:21 AM
ticki2's Avatar
All the connections on the alternater , voltage regulator and batteries are clean and good , done at least twice . I'll have to check further down the line . I can see the bad connection/wire causing the up and down charge , it's the lights pulsing that has me really puzzled .
Old 01-09-2007 | 10:59 AM
ticki2's Avatar
Well it turned out to be the newly installed rebuilt alternator . Put another one on and all is good , charges properly and no more lights pulsing .
Diesel-Dan
20
09-22-2019 09:34 PM
GLHS
02-25-2011 10:12 PM
Smokin96_12v
01-21-2010 01:06 PM
The_g10
10-30-2002 07:47 AM
Quick Reply: strange charging
