straight pipe
Old 12-19-2006 | 09:49 PM
srv8800's Avatar
straight pipe
who makes a good 4" turbo back exaust? thanks
Old 12-19-2006 | 09:55 PM
TIMMY22's Avatar
all depends on how much you want to pay, and how long you want it to last.
there is 16ga and 14ga aluminized and S steel. most are mandrel bent.
you can pay anywhere between $200.00 and $600.00
you can even custom make one yourself.
Old 12-20-2006 | 06:57 PM
lews930's Avatar
try pinnacle performance. jerry jardine does a turbo back for $230. cost me $275 to my door
had to reflare the ends to get the pipes to slide over one another but it's a 4" and it sounds awesome
lewis
Old 12-20-2006 | 07:58 PM
srv8800's Avatar
14ga stainless sounds great.. where do i get that?
thanks
Old 12-20-2006 | 08:17 PM
realtreehunter's Avatar
you can also go to ebay and type i think 4" straight pipe dodge and it should come up and pretty cheap too
Old 12-20-2006 | 08:24 PM
drolex's Avatar
lewis
I second this. This is the exhaust I got. I bought it on ebay with the muffler to my door for $310. You can get it without the muffler for less. The straight through muffler was only $40 more so I got it. It's a sweet exhaust. It comes ready to go. Mine was handled roughly in shipping so some of the tips on the pipes were bent a little. I just bent them straight with some pliers. You can just buy it on ebay or whatever and tell them exactly what truck you have. If your truck came with a catalytic converter and you need to do emissions, then you will need to keep the cat or get a new one from someone with a 2004.5 or newer truck (they come with 4" cats) like I just did. I'm assuming you want a 4" exhaust. 4 inch is good.
Old 12-20-2006 | 09:48 PM
TIMMY22's Avatar
Aluminized Steel has been hot-dip coated with a special, corrosion-resistant aluminum-silicon alloy. Aluminized steel gives you the look and feel of aluminum with the superior strength and lower cost of steel.
409 Stainless Steel is a cost-effective, high-grade, low carbon steel with excellent corrosion resistance and strength. It sports a superior shine to aluminized steel, and only 304 stainless is more resistant to rust.
304 Stainless Steel has the highest chromium and nickel content of any stainless alloy, making it the most corrosion-resistant material in the industry. 304 stainless is also capable of a mirror-like polished shine that is like chrome.
a litttle pricey...
http://cgi.ebay.com/ebaymotors/MBRP-...8649QQtcZphoto
Old 12-30-2006 | 09:31 PM
Forrest Nearing's Avatar
why isn't this thread locked?
Old 12-30-2006 | 10:12 PM
TIMMY22's Avatar
who says were driving on public highways?
Old 12-30-2006 | 10:41 PM
this post gets locked
but this one doesn't!?
obviously I don't own/run the website, but the lack of consistancy is confusing
Old 12-31-2006 | 12:33 AM
bigwhite59's Avatar
I've got the Jeg's subway tunnel exhaust. about 360 i think to my door. Have had it for a little over a year and only rusts where i welded it together instead of clamped. 4" DP to 5" exit's behind pass wheel. need to remove the spare though.
MTC
07-14-2009 06:27 PM
Jordan5687
02-14-2007 05:00 PM
yarddog
08-30-2005 09:01 PM
PADZZ
02-09-2003 08:33 AM
Quick Reply: straight pipe
