Stock W-250 build up Help
........Moved to Gen Forum....
I'm ready to invest a little into my Stock 1993 w-250 4x4. She is just a baby with 247,000 miles on a stock motor and tranny.
I tow a medium size car hauler trailer on occasion and use this truck as my backup vehicle.
I'd like to keep her forever but feel like she needs a little bit more .......power.
My tranny is first on the list.
There is a lot of info about these trannys and I get a bit overwhelmed, can you guys give me some advice about picking the right tranny setup?
- New or rebuilt tranny?
- performance valve body?
- tourque converter (low stall vs other)
These are areas I see people talking about. In your opinion, is there a winning combination that really makes your truck work well?
I will turn up the power on the motor a little but nothing real wild. I would like to put an exhaust brake on it to after the tranny is dialed in.
Let me know what you guys think. And, thanks
https://goo.gl/photos/RvafxA4erUW779x86
See, CA does get snow
If you are wanting to run an EB, you'll need to swap up to a 47RH with the lock-up converter. With the 518 it'll be a waste of time and money to try and run an EB as there is no lock-up between engine and trans.
mrwaters
12-28-2005 10:11 PM
