Steering Wheel not centered how to fix?
My steering wheel is off center, tips to right when I'm driving straight.
I jacked the front end and turned the wheels for the PS pump bleed...
did I mess something up? Can't remember how it drove before, but I'd sure like to fix it...
That should be just the draglink adjustment between the steering box and axle tie-rod bars. Trial and error till you get it right. Adjust... drive...adjust a little more...drive...etc, till you get it centered...
Beware that when you adjust that the bolt side of the split sleeve isn't pointed towards the steering dampener. Doesn't look like it with the wheels straight but when you turn tight the sleeve will hit the dampener and bend or cut it.
9MM
10-06-2011 09:45 PM
LanceK
07-12-2006 04:55 PM
