Steering Problems
Steering Problems
Took 97 To Garage And Had Front And Rear Sway Bar Links, Power Steering Pump, Steering Box, And Trac Bar Replaced. Now The Steering Wheel Is Upside Down Going Straight. Will Alignment Fix Or Did Mechanic Do Something Wrong? And Help Would Be Great. Thanks
Be real careful with that until you get it fixed. The clockspring (runs to airbag and cruise) is only designed to turn so many times. With the steering wheel off a 1/2 turn already you probably don't want to turn it to the lock so that you don't break the clockspring. Trick is going to be figuring out which way it is off (left or right). Good luck!
Uhh... I think the mechanic messed up. I would get it fixed and then never go to that shop again! It's happened to me in the past as well. I don't understand how a mechanic can call it an alignment when the steering wheel is off center.
Any Mechanic who doesn't do at least those two things, is just being lazy.
Dean Snow
11-14-2007 04:36 PM
unioncreek
06-29-2005 02:00 PM
OHFarmboy
02-25-2005 11:30 AM
06-05-2003 09:27 PM
