Started KDP fix..
Old 08-13-2007 | 08:56 PM
ChargerLighting's Avatar
Started KDP fix..
Not much to say really...its'..."fun"
So far its' taking forever; my main holdup was the 4th fan bolt behind the pulley. TST tells you to trim down a wrench or use the open end...yeah right. I found out - to save yourself from the torture of the stupidly placed bolt - that if you remove the 6 10mm bolts from the fan pulley & slide it forward, that gives you much more room to work with. (I just held back on 1 & broke the other 5 loose...you can actually hold back on the fan nut w/channellocks & break them loose that way I believe). I actually weaseled in a 1/4" ratchet/short socket to break mine loose.
But, I just have the balancer to remove, then it appears I can get into the case & see if the KDP moved at all.
Old 08-13-2007 | 10:15 PM
kelownadiesel's Avatar
ur supposed to take the fan off first then the pulley,its very easy after the fan and shroud is out.
Old 08-14-2007 | 09:06 PM
I would've had I been able to get the fan nut broken loose. I have the actual fan removal tool, but could only find part of it. .
But, aside from having to re-adjust the RPM sensor tomorrow, its' done.
The KDP DID move (see pic) but not much.
Most of the stuff went back on easy. Would've been nice if I had remembered how the serpentine belt went... I cursed at it for a while.
All in all it's just a bunch of stupid small steps piled together & its' time consuming. But, now I know how to do it or most of it
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
Rickcher
07-13-2009 01:22 PM
ryan10
01-16-2008 07:54 AM
bkay
03-12-2003 06:44 PM
Quick Reply: Started KDP fix..
