Start a 98 12 V with transmission removed
Old 08-21-2008 | 11:49 AM
gozapper's Avatar
Hi, I just got a 98 12 valve that the auto transmission is out of.
I want to start the engine to check it out before I remove it.
I tried to jumper from the battery to the starter solenoid and crank it and not getting it to fire.
Does this model have a electric lift pump?
Is the computer causing the the shut off solenoid not to energize?
Thanks,
Tom
Old 08-21-2008 | 12:12 PM
offroad's Avatar
Thanks,
Tom
You should be able to put the shut off solenoid in the run position manually. I believe all 12V motors have a mechanical lift pump on the drivers side of the motor. Might want to take a broom handle and push the plunger on it (a bunch of times) to prime, if it hasn't been running in a while.
Old 08-21-2008 | 02:17 PM
gozapper's Avatar
Got it going, Thanks.
Tom
AirForceman
01-13-2010 02:19 PM
CoolumConst
10-11-2008 10:00 PM
pwabbott
12-26-2002 05:13 PM
Lary Ellis (Top)
11-23-2002 12:41 PM
Quick Reply: Start a 98 12 V with transmission removed
