Stalling When Cold....??
Old 10-11-2008 | 01:10 PM
Katmandu's Avatar
Question Stalling When Cold....??
My truck stalls out when the engine is cold and the temps drop below 50F or so.
The truck starts right up and the heater grid appears to be working fine.
It's just when I come up to stop signs/traffic (when the engine is still cold) that the engine stalls out.
This is a REAL PITA.
After the engine warms up (5 minutes or so). It never stalls out. ONLY when the engine is COLD does it do this.
This problem worsened after a 3KGSK was installed.
What do I need to do to correct this issue ?
Old 10-11-2008 | 06:18 PM
Dartmouth 12V's Avatar
I would suspect that your idle is too low. It should be around 850rpm with the AC on while warm. The factory tach is often off by a fair amount.
Old 10-11-2008 | 08:54 PM
1-5-3-6-2-4's Avatar
I would tend to agree. bump up your idle and verify engine speed with an optical hand tach.
Old 10-11-2008 | 10:58 PM
Fueling around's Avatar
This is very common with a 913 pump and GSK installation. If the idle speed adjustment doesn't help you can try changing the governor spring tension.
Old 11-07-2008 | 03:08 PM
roughstock's Avatar
I have same problem. I think the 3gsk made my symptoms worse.
I have Idle set at 900-950 according to tach.
I was thinking about tightening down the retainer nuts on the gsk springs
Anyone?
Old 11-07-2008 | 03:47 PM
Lil Red's Avatar
Had the same problem in my truck and it was the torque converter not disengaging and stayting locked up in which nearly stalled out the truck. New tranny and torque converter and no more problems.
Old 11-07-2008 | 04:19 PM
Anyone?
I was thinking to loosen them. The spring tension should be snug plus 2 clicks. Many 913 pumps had very tight stock springs.
Old 11-07-2008 | 05:46 PM
Tate's Avatar
Try tightening the springs a click or two. Your idle will come up when you tighten the springs. I would go a click and readjust your low idle screw till your happy. If you tighten your springs too much though, you engine may hang at a high rpm instead of coming down when you get off the throttle. You know you have gone too far.
Diesel Dave2
04-05-2007 12:18 PM
mtowle98
11-20-2006 07:58 PM
george7941
10-07-2006 08:08 AM
george7941
03-15-2006 09:31 PM
Quick Reply: Stalling When Cold....??
