Squealing when in 4WD
Old 12-08-2008 | 11:45 AM
RGBruce3's Avatar
First snow this weekend and first time in 4WD for some time. Drove about 15 miles before the truck developed an ever increasing squeal from underneath. The sound is a little like brake pad squealers against a rotor. Increases and decreases with speed. Stops completely when stopped or out of 4WD and restarts immediately when shifted back into 4HI. 4WD seems to work fine otherwise. Light comes on and off as usual. I’m thinking it’s the front driveshaft U joint, but not sure. Does the front shaft turn or free wheel when out of 4WD? Both front axel joints have been replaced. Transfer case fluid is good. Has anyone experienced this problem or have an idea what it may be?
Old 12-08-2008 | 02:17 PM
infidel's Avatar
Same size tires all around?
Old 12-09-2008 | 11:16 AM
RGBruce3's Avatar
Yes, all the same size Bridgestone Revos and stock rims.
Old 12-10-2008 | 06:03 PM
NCYZ1V's Avatar
Did you check the U joints ??
they have been just free wheeling.... till you put (it in 4x4) and then stress on them they may squeal.
Old 12-10-2008 | 10:19 PM
dozer12216's Avatar
Check lube level as easy for leak to drain the 2+ qts of oil out. Does it change when going around curve? Read owners manual about when can use 4H. JMHO
Old 12-12-2008 | 11:35 AM
RGBruce3's Avatar
Finally had a moment to slide underneath to take a closer look. NCYZ1V you are right on. The shaft does indeed turn freely when out of 4WD. I was surprised to find the squeal was easily duplicated by turning the shaft with my hand. The sound is coming from the front U joint. I dropped the shaft out last night with the intention of a couple simple U joint replacements but quickly learned the rear CV joint has a little more to it. I’m going to press out the joints this weekend. Any hints on R&Ring the CV joint would be greatly appreciated.
93Fury
03-31-2010 01:33 PM
wrangler04
07-17-2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
12-29-2006 07:17 PM
95black2615
12-20-2006 06:37 PM
1320
05-06-2003 06:30 PM
Quick Reply: Squealing when in 4WD
