sqeaky clutch pedal
Old 01-06-2008 | 02:16 AM
97RamBeast's Avatar
sqeaky clutch pedal
hi,
I was wandering if anyone could tell me how to lubercate my clutch pedal? Is this a common problem? Its a 97 cummins with a 5spd. Any help would be great!
Old 01-06-2008 | 04:25 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
spray some lube on it
Old 01-06-2008 | 12:25 PM
Box5's Avatar
put some grease on the pivot where the master cylinider rod connects to the pedal. Mine had a real annoying squeak, I put some high temp grease (all i had at the time) and havent had the squeak come back for months. All you do is take the little clip that secures the master cylinder rod to the pedal, pull it off put grease inside it, and ur good to go.
Old 01-06-2008 | 03:06 PM
97RamBeast's Avatar
thanks i will give it a try! I cant stand it any more, its the worst sound ever!
Old 01-07-2008 | 03:48 PM
manureman's Avatar
I had a 99 5 speed that did the same thing. The clutch pedal pivoted on a steel rod that had a plastic bushing it rode in. The squeak was the rod rubbing on the plastic bushing. I don't think there was anything there for lube, but I greased it up good and the squeek went away.
Old 01-08-2008 | 11:16 AM
walexa's Avatar
I agree with manureman.
Through the process of elimination, I sprayed lubricant where the master cylinder rod attaches to the clutch pedal, then where the rod goes through the electronic module that prevents engine starting w/o clutch depressed, and sure enough, it was the last thing I tried.......where the clutch pedal pivots. Just a shot of multipurpose lube and it quit immediately. Mine would only squeak when it was cold. Once the truck was warmed up it would quit squeaking. Did the same thing last year but I had forgot what I had to spray to make it stop.
I am sure greasing it up would last longer than spray lube.
Waylan
600 Megawatts
03-26-2008 07:09 PM
WACTD
07-25-2006 11:41 AM
Kent
06-21-2003 05:54 PM
Jones0027
05-15-2003 05:29 PM
Quick Reply: sqeaky clutch pedal
