sputter at any rpm
sputter at any rpm
when i give it throttle it sputters, when i just stap it it wants to die but stays running and puts out black smoke. i just installed ddp2 injectors that were leaking, but i got that fixed and the problem still exist. im hoping its just the timing (slipped) and not a blown head gasket. no coolant lost and i cant smell fuel or coolant on the dipstick. im at a lost. it has totally ruined my holiday weekend
Sounds like you aren't getting enough fuel.
You need to check fuel pressure, could be plugged filter(s), bad overflow valve or lift pump.
How to check fuel pressure https://www.dieseltruckresource.com/...41&postcount=9
92smokin blacky
03-15-2011 12:06 AM
12valve
29
11-22-2006 01:02 AM
