Speedo and Sensor
Speedo and Sensor
First of all, sorry if I am over-posting.
They are distinct questions however.
My speedo works fine. My brake and ABS lights are on.
I read in the forums that there may be a sensor in the transfer case as well.
Is it possible that the speedo can still work if the rear sensor is bad?
Thanks in advance,
-ultra
Thanks in advance,
-ultra
The older trucks (such as yours) does infact have a sensor in the t-case (or tranny, in 2wds). I don't know if its related to the ABS system or not like in the 98+ trucks, so it may have nothing to do with your lights. Are they on from the get go, or do they come on after driving it for a while (past a certain speed)?
Code 7 seems lousy.
What's the most efficient way to eliminate all the ABS stuff? Remove it and put in some lines going through?
I honestly don't need any warning lights for brakes, I can sense everything I might need to know through the controls.
Actually, I had thought of just eliminating all of it but disabling wouldn't be a bad option necessarily.
Could I easily have brake light functional with ABS disabled and maybe ABS bulb pulled? The only thing I can think of use for brake light for is if wife drives truck and doesn't know e-brake is on.
92smokin blacky
05-25-2012 10:46 AM
TexasHardcore
05-17-2005 09:03 PM
