Some front end Questions..
Old 03-22-2009 | 02:44 PM
Wicked500R's Avatar
Does anyone know what position the lower control arm bolts should be in for max caster? Full forward or all the way back?
Will it be ok to use a 3-6" drop pitman arm with 2-3" of lift ?
I have load range "E" tires rated for 80psi... I have always kept 80 psi in them. Is it safe to drop down to 50 or 60 psi ?
Is there a certain way aftermarket coil springs need to be installed ?
I am trying to get my "DW" issues under control and will be totally ripping my front end apart for a rebuild. Thanks for any help !
Old 03-22-2009 | 10:28 PM
rstrucks's Avatar
- You get more caster when the cam bolt is adjusted forward pushing the lower link out. That will make the axle "lean back" giving it more caster.
- I'd try to do with out any drop arm first. If you don't have bumpsteer, you shouldn't need one.
- usually there is some sort of "pig tail" wound into the end of springs and it fits into a relief on the axle end.
1999blackcloud
01-26-2010 08:52 AM
GR40RCapri
10-30-2007 09:37 AM
Gordonville
04-18-2005 09:45 AM
Sux 2B urTurbo
23
08-14-2004 11:56 PM
royta
07-13-2004 06:54 PM
Quick Reply: Some front end Questions..
