snap ring
Old 03-15-2004 | 04:22 PM
AZGEARPRO's Avatar
snap ring
I Have to change out my cool side housing on a turbo hy35, the housing is damaged and I received a replacement. I cannot figure out how to remove the snap ring. I have removed the ones with built in tangs but this one has holes. Anyone have any ideas on how to remove it?
Old 03-15-2004 | 04:27 PM
Mcmopar's Avatar
Get a set of snap ring pliers with the small pins.
Old 03-15-2004 | 04:40 PM
AZGEARPRO's Avatar
I tried that but they keep slipping, this snap ring is form Hell
Old 03-15-2004 | 09:04 PM
Jeremy Cusick's Avatar
You're probably using the wrong size snap ring pliers. They make different sizes for larger or smaller snap rings.
Old 03-16-2004 | 07:59 AM
redramnc's Avatar
For snap ring removal one size does not fit all. K-D Tools makes a set that has interchangeable tips of the most common sizes. I have a couple of sets that I have picked up over the years - most came from NAPA. When it comes to snap rings the correct tool for the job is the only tool that will work without alot of *&$$^#@*(
RonP
02-17-2010 10:30 AM
RRC
05-14-2007 12:45 AM
HaulinBut
05-12-2006 04:06 PM
StrokeThis2500
12-31-2005 06:19 PM
Quick Reply: snap ring
