Smoking
Old 04-08-2004 | 05:45 AM
K-80's Avatar
Angry Smoking
I have a customer with a 94 12 valve, when he starts it cold it smokes a real lot , it also seem to run on 3 cyls untill it gets warm. any suggs.
Old 04-08-2004 | 06:36 AM
vssman's Avatar
What color smoke? Just a guess but, timing may have slipped. How's the power when warm?
Old 04-08-2004 | 06:39 AM
Smokee's Avatar
Another thing to check is the pre-heaters. Are they cyclling properly?
Old 04-08-2004 | 07:48 AM
MnTom's Avatar
Do a search for "timing" and you will find lots and lots of reading. The way you describe the symptoms reminds me of the way mine was. The timing had slipped to the point that it was even getting to be somewhat hard to start when it was cold. It ran good after it warmed up some though. It missed and smoked enough that it was almost embarassing to drived until it warmed some. Check the timing and reset it to 15.5-16.5 and your customer will be alot happier.
Tom
Old 04-08-2004 | 09:36 AM
infidel's Avatar
Blue-white smoke:
Blue-white smoke may be noticed at engine start-up whether the engine is at normal operating temperature or not. Blue-white smoke can be observed at all ambient temperatures and should not last longer than a minute or two after the vehicle has been driven. Blue-white smoke can return when ambient temperature is below 10 degrees C (50 degrees F), and after the engine is warmed up due to extended idling. This is due to combustion chambers cooling own during periods of extended idling time. Heavy blue-white smoke may also occur if the engine is operated at full throttle with the transmission in neutral or park. If you see continuous Blue-white smoke while driving, then you probably have air being sucked into the fuel system.
White smoke:
White smoke and blue-white smoke share some of the same characteristics. White smoke is fuel not being burned. Extreme white smoke can be caused by the combustion chambers cooling down. One cause of this could be incorrect injection pump timing. Coolant getting into the combustion chamber can cause white smoke also. Possible causes are blown head gaskets, cracked heads cavitation, etc.
Black smoke:
Black smoke is caused by an over rich mixture and normally occurs whenever the engine is working hard. Like going up a steep grade, being loaded heavy or during heavy acceleration. More black smoke can be observed when the vehicle is operated at higher altitudes because the air is thinner. A dirty air filter is also another cause of excessive black smoke. If black smoke is noticed while the engine is idling at low altitude or under normal driving conditions this condition should be diagnosed a.s.a.p. to prevent engine damage.
Blue smoke:
Blue smoke is not normal and you do not want to be driving behind a truck that produces it. Blue smoke occurs when oil is entering the combustion chamber and is burning along with the fuel. Blue smoke usual indicates a condition which should be corrected a.s.a.p. Blue smoke also smells like oil burning. Possible causes include valve seals or cracked piston rings.
from
http://www.freeautoadvice.com/diesel/smoke.html
Old 04-08-2004 | 07:20 PM
K-80's Avatar
How do i check / adj. timing
Old 04-08-2004 | 08:09 PM
MnTom's Avatar
There is good instructions here: http://dodgeram.info/tsb/1994/18-10-94a.htm
Tom
Old 04-09-2004 | 05:50 AM
K-80's Avatar
Thanks.
jsr21
07-16-2003 02:16 PM
camomullet
03-26-2003 11:42 PM
da-kine
02-23-2003 10:47 PM
cwbronc
12-11-2002 12:36 PM
flamered
12-05-2002 06:01 AM
Quick Reply: Smoking
