smoked wire
Old 01-01-2009 | 09:50 PM
babe blue Ox's Avatar
smoked wire
does anyone know what ES1 is I smoked a wire marked ES1 it comes off the pos side of the driver side battery I put a 15amp inline fuse in it and it keeps blowing the fuse, everything still works Im stumped my repair manual doesnt show the wire.
Old 01-02-2009 | 08:28 AM
GAmes's Avatar
Need more than that. Year of truck, color of wire, etc.
Old 01-03-2009 | 12:06 AM
smoked wire
ooops sorry Im new to posting ? ITS A 97 with a 5 speed and the wire is red there are two wires that come off the batt and go into a loom the red one melted and I put a 15 amp fuse in it which keeps blowing
Old 01-03-2009 | 02:46 AM
TexasHardcore's Avatar
Sounds like a fusible link. Trace where the wire goes, found out what it is, then replace it with the right fusible link. Could be the fusible link from the grid heaters, or the shutoff solenoid. Both common on these trucks. I know the shutdown solenoid fusible link is a 65amp. If the engine starts up and turns off fine, then it's likely the manifold grid heater relays.
Old 01-03-2009 | 02:50 AM
Tate's Avatar
AFAIK, the only feeds directly off the battery are to the starter, the grid heater, the fuel shut off solenoid and to the PDC. All of them draw much more than 15 amps. Corrosion in the wire will increase resistance in the wire and will heat up when current is applied.
Old 01-03-2009 | 11:30 AM
thanks I will look into it, what are grid heaters?
Old 01-03-2009 | 01:54 PM
infidel's Avatar
Read this http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
Old 01-03-2009 | 03:22 PM
thanks, I was wondering why my lights flicker at night sometimes, heres somthing else my temp gauge fluctuates between 140 and about 180 constantly it will come up then slowly drop to 140 then slowly go back up to about 180 then drop.
Old 01-03-2009 | 04:09 PM
rattlerbob5.9's Avatar
Normal -when it does not do that then it is time to be concerned.
If you are working the truck hard then the temp might stay up at 180.
Old 01-03-2009 | 05:25 PM
GAmes's Avatar
The grid heater fusable links are black. Not your problem. The 97 has two smaller wires that go into a common loom. One is an orange fusable link that is connected to a red/tan wire. It sends power to the fuel heater relay that is mounted on the firewall. The other is a dark blue fusable link that is connected to a red/black wire. I think this is the wire you are speaking of. It goes to the fuel shutdown relay that is mounted on the firewall to the right (as you are looking at it from the front) of the fuel heater relay. Power out of the relay to the fuel shutdown solenoid is a red/violet wire. Do you need more info than this to trouble shoot?
Old 01-03-2009 | 06:21 PM
infidel's Avatar
Seems like if his truck is running fine it must be the fuel heater link.
Since it's blowing I'd leave it be before the heater melts the connector causing a fuel leak.
Lot of folks running with no fuel heaters due to the problems they cause.
Old 01-03-2009 | 06:37 PM
GAmes's Avatar
That is where I'm confused. He never said if the truck is running. If it is, I'd recommend removing the entire fuel heater assy. I removed mine and it wasn't causing any problems, just wanted to get it out of the system. I haven't been to the great white north since then though.
Old 01-04-2009 | 11:24 AM
infidel's Avatar
In his first post he said everything still works.
I assumed that meant the truck was running.
Old 01-04-2009 | 12:23 PM
yes the truck runs fine every thing works I appreciate all the info you folks have given this site is awsome thanks again fellas.
duallydave
01-22-2009 04:50 PM
Rollin Smoke
10-24-2006 10:24 PM
Txwelder
02-11-2006 10:32 AM
matthopp
05-11-2004 04:38 PM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: smoked wire
