Slowwww starter crank
For about a week or so now, the truck has been really slow to crank over.
I have to give the truck throttle to get it to start because it cranks SOO slow.
I have 211k.
Batteries & alternator are good.
Should I just replace the starter?
Thanks in advance
Garrett
I have 211k.
Thanks in advance
Garrett
Starter. You will fry it for good if you keep cranking it as it is now, if its not already totally toast.
BTW, mine did this same thing, then one day a long way from home it just quit altogether. Its already warned you, so change it asap.
Jimmy
Jimmy
i had the same problem on mine and it was the starter. should have changed it before i did the batteries and the alternator. bought one off ebay and it started great.
Originally Posted by Geico266
Your starter contacts are gone. You can replace the contacts and solve the problem for alot less $$.
If the windings are not damaged from low voltage.
Originally Posted by Bobcat698
Think I'll pick up a starter on ebay.. $125 shipped.
Why not get yours rebuilt?
I paid 75 bucks to get mine rebuilt the last time, Its alot less than 125 and u get it back quicker...
Rick
Rick
Rick
I got mine for $117 shipped.. It'll be here tomorrow. I gotta get it up and running ASAP, dont want to be stranded!
Garrett, I rebuilt my starter with the oversized contacts and new plunger from Fosters and it took longer to get the starter out, then it was to rebuild it. cost like 25 clams.....
