Sliding the plate?
Old 03-01-2004 | 09:24 PM
INJECTOR JACK's Avatar
Question Sliding the plate?
Was wondering what you guy's mean when you talk about sliding the plate? I now it is a cam plate adjustment just wondering about the lingo and what it means?
Old 03-01-2004 | 10:06 PM
jaconst's Avatar
I believe it is the fuel stop plate.
Old 03-02-2004 | 12:03 AM
Sidewinder's Avatar
The mounting holes on the plate (under the AFC housing on the injection pump) are slotted. By removing the housing and loosening the screws on the plate you are able to SLIDE the plate forward or backward on the screws. Usually the SLIDE is towards the front of the engine (forward) to increase the amount of fuel delivered. Everyone always says to mark the stock location on the plate so you will always have a reference to the original setting position.
I have slid my plate all the forward and it seems to run a little stronger with no real increase in smoke......Yet!!!
Old 03-02-2004 | 09:24 AM
infidel's Avatar
This website gives good instructions on changing the plate, same procedure is pretty much used to slide it.
http://www.tstproducts.com/power_install.html
Old 03-03-2004 | 12:08 AM
dalton4's Avatar
Injector Jack, play safe and have a pyro gauge before sliding the plate forward. Increased fueling means more heat.
Old 03-05-2004 | 02:20 PM
Talking Sliding the plate!
Thanks for the replies guy's. I figured thats what you were talking about!
Lambo
03-09-2004 02:04 PM
kingofdodge7131
14
02-29-2004 03:13 PM
yrusoslow2
09-11-2003 07:46 AM
berner
06-11-2003 06:54 AM
dma251
14
05-08-2003 12:48 PM
Quick Reply: Sliding the plate?
