Slid plate and AFC full forward
Old 11-04-2007 | 02:04 PM
TurboChris's Avatar
Hey everybody, I just got my Dodge about a month ago. Based on info I read on here, I slid my plate and AFC housing full forward. I didn't feel any difference in power. I also installed the BHAF, and removed my cat. Am I expecting too much? The truck had only 92,000 miles on it, when I got it. It was very well maintained and no mods done before I touched it. Some guys say not to put the plate full forward. Exactly how far from full forward?
Old 11-04-2007 | 02:13 PM
aksparkey01's Avatar
you should just be seeing alittle more pre boost fuel. not gona make that big of a difference. you are probally gona have to put a differnt cut plate in. not sure what to reccomend with the stock auto trans. but i would guess maby a plate from a 210 pump. #5 maby (just guessin on that *)
Old 11-04-2007 | 02:17 PM
pete97's Avatar
Don't you mean 215 pump??? TurboChris, do you have an auto or a 5spd? A #10 plate would be a good choice to use. I have it in mine and it really woke the truck up!!!!!!
Old 11-04-2007 | 02:20 PM
yes i ment a 215 pump
Old 11-04-2007 | 02:23 PM
pete97's Avatar
Ok, I'm new too. Just wanted to make sure I wasn't missing something!!!!!
Old 11-04-2007 | 02:26 PM
i bought an aftermarket plate, but wasnt really happy with it so i just got the profiles for the differnt # plates off here and ground my stock plate to a 100.
Old 11-04-2007 | 02:45 PM
Box5's Avatar
save ur money and grind a 10 plate. Make sure u have gauges first though, And ur tranny might not like it. The Plate will show performence when u get above 6psi boost im pretty sure. The afc and starwheel will help the pre-boost fuel tuning. And if u have a stock auto, that won't help performence at all, u could have 500hp but if ur TC and VB aren't upgraded, u wont notice much power gain unless ur Locked up in overdrive because the trans will just suck up the power and kill it.
Dhorn33
16
09-23-2008 10:24 PM
West Coast
07-04-2007 11:25 AM
lews930
10-27-2006 08:58 AM
mr T
32
03-07-2005 04:06 PM
whiteknight
13
12-29-2002 09:30 PM
