Sealant for Fuel pressure gauge fittings? Metal lines to hose?
Im curious as to what you guys use to seal brass couplings instead of teflon tape (which turns to goop once the fuel hits it).
Plumbers pipe dope maybe? or silicone RTV?
Also has anyone here replaced the metal lines from the tank completely with hoses and what are your opinions on that?
i have heard that antisieze will seal the threads for diesel fuel but i use permetex #2,replacing the fuel lines isn't to bad of a job,i removed all the old ones completely and ran rubber hose all the way.
Ahh, so the fuel sender assembly has the pickup and return that have push-on connectors with barbs and theres a short rubber section that joins to the steel lines? I think thats what I saw in there last time I dropped the tank.
Ive got it down to about 15gallons now I think I might try this again tomorrow if I can find a local source for good fuel hose.
Any recommendations on where to find USCG-rated diesel fuel hose online if not?
http://www.houseofhose.com/
Permatex #2 is cheap, easily available and works excellent for thread sealant.
leathermaneod
08-04-2015 12:44 AM
ptgarcia
19
06-11-2008 08:38 PM
I PASS GAS
04-26-2005 09:51 AM
