Safe EGT's and duration?
Just curious about this one. I know hitting 1500F is not good but if you get into it and look up to see 1500F whats the odds youve done any damage?
I need to find some way to hook up an audible alarm on the pyro so I know when Ive crested 1400
If you hit 1500 degrees briefly, I'd say the chance of damage is 0%. I hit it fairly routinely for a few seconds. Well, I say I hit 1500 degrees-that's as high as the gauge reads. It probably goes higher than that.
Ive hit 1500 degrees in mine several times but only held it for maybe two seconds. I think everything is fine if you just hold it for a few seconds, or at least mine has been so far, and i KNOW some of these trucks that you see pullin the sled are over 1500* when theyre on the track. I think as far as a safe temp. to hold for a period of time is around 1250* or 1300* max. A little audible alarm would be pretty cool, or maybe an inicator light that warns when you reach 1400*s. You just have to train yourself to keep a close eye on your gauges.
Lrdchaos
04-09-2008 04:15 PM
swktk1
09-02-2007 11:26 PM
O5DodgeRam5.9
22
08-12-2007 05:17 AM
morkable
29
10-27-2006 07:31 PM
streetsmoker
14
01-29-2006 06:09 AM
