Run srw on a drw?
Old 01-03-2011 | 10:48 AM
GLHS's Avatar
Run srw on a drw?
Looking at a 98 quad cab 12 valve 3500 5 spd and was wondering if it is possible to put singles all the way around.
If it is possible, how much wider is the drw compared to the srw in 98?
Was thinking of using some 3rd gen 17"s to fit over the drums and calipers if needed.
Old 01-03-2011 | 10:54 AM
d-rod's Avatar
yes if you take off front adapters wheels will bolt up. i think back tires will be out a half inch farther but no big deal. wish i had done some measuring and found this out before i went to the trouble of buying and changing rear ends. although i did gain a limited slip and thats nice.
Old 01-03-2011 | 11:46 AM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
The rear end from the dually will be several inches wider on each side unless it was a cab/chassis truck, then it will be narrower than a regular dually and still a little wider than a SRW truck. I don't know the exact measurements. There is a lot of bad information out there on this subject. If I can flag down a 2nd gen dually I'll get some measurements. I can give you the SRW measurements if you want. I saw a mega cab dually run singles, but he left his front adapters on and bought wheels with extreme backspacing and they still sat way out.
if you just remove the front spacers, the rear will be quite a bit wider. The only real way to do it is swap rears.
If you think about it, it makes sense. On the regular dually trucks, the front tire and inner rear make almost the same track. now take off the front adapter and how much difference would there be front to back? You could always take off the outer rear wheel and run it like that lol I"ve seen that done!
Old 01-03-2011 | 12:41 PM
d-rod's Avatar
yes both those wheels almost run in same track and both are mounted same direction and are super offset the same direction, so for no more work then it takes take the time to measure before you go to a bunch of work of swapping rears like i did. their is a pic of a truck on here that just changed wheels and removed adapters, i see if i can find it and post it, guy made me feel like an idiot for doing what i did. i would have never believed it would come out as close as it did, but pic. worth a thousand words.
Old 01-03-2011 | 12:44 PM
d-rod's Avatar
https://www.dieseltruckresource.com/...d.php?t=275767
this is the thread i was talking about, you can tell backs stick out little farther but!
Old 01-03-2011 | 01:32 PM
GLHS's Avatar
That does not look bad at all!
Here is some info I posted a while ago.
SRW D80 width from a 1997 (drums); 13-3/8" from center of spring perch to wheel mounting surface.
SRW D80 width from a 2002 (disks);..14-1/4" from center of spring perch to wheel mounting surface (in my 1st gen).
DRW D80 width from 2002 cab & chassis (disks); 12-7/8" from center of spring perch to wheel mounting surface. I don't know if the frames are the same width though?
So, anyone have this measurment for a DRW pickup from a 1999 or earlier truck?
I say 1999 or earlier because when Dodge offered the 16x8 factory aluminum wheels, the rear ends got a touch wider and the drums are/look different from my findings.
Old 01-03-2011 | 02:06 PM
d-rod's Avatar
don't want to step on toes and say i'm right, just putting down what i found out when i changed my truck.
Old 01-03-2011 | 02:13 PM
GLHS's Avatar
Your not stepping on toes; just looking for an exact measurment for this 1998 DRW D80.
Based on the picture in the attached thread, it does not seem there is that much difference; or at least not enough to make it look bad.
Old 01-03-2011 | 02:16 PM
d-rod's Avatar
and alot less work good luck!!
MikeRP
79
11-21-2016 10:19 PM
lawdog800
19
03-31-2011 09:26 AM
89dieselkong
04-05-2009 05:20 PM
Roger Portmann
12-10-2008 09:20 AM
dragginlx
15
03-09-2007 11:32 AM
Quick Reply: Run srw on a drw?
