run @ what rpm?
Old 04-17-2004 | 09:41 PM
4doogie's Avatar
Question run @ what rpm?
Hey dodge diesel brothers, had a question. What is a safe maximum rpm to run my 97-dodge stock? The red line starts at 3,000 but if I ‘m going up a on ramp and want to pass a ford and drop it into second what rpm could I safely go up to?2,800? Advance thanks Chris
Old 04-17-2004 | 09:49 PM
The engine is governed, with a stock pump you can't over-rev it. Just floor it and shift when it stops pulling. The redline is meaningless.
Old 04-17-2004 | 10:47 PM
4doogie's Avatar
Thats cool, what is the max if the pump was changed
Old 04-18-2004 | 12:41 AM
SjLingenfelter's Avatar
Pump was changed and springs were changed depending on which springs you went with would either be 3200 or 4000.
Old 04-19-2004 | 12:11 AM
4doogie's Avatar
with a stock pump will it over heat the engine at all or cause damage to the pump itself?
Old 04-19-2004 | 06:23 AM
bulthisl's Avatar
Hasn't hurt mine any !
You just don't want to trash it at 4k on a daily basis.
: Eddie :
Old 04-19-2004 | 03:03 PM
4doogie's Avatar
when i put my foot to the floor what is the max rpm i will get with the stock pump governed?
Totallyrad
09-25-2010 11:15 PM
ppsi
13
04-13-2004 03:49 PM
fishin fever
02-22-2004 08:32 PM
Quick Reply: run @ what rpm?
