Rough At Idle Delv. Valves
Old 10-13-2008 | 09:21 PM
GARLAND's Avatar
Hey have'nt been for a while but need some help. With the mods i have timming, injectors, turbo, 10k plate and exh. The truck ran good 15.24 in the quater first time for truck and me. I put some delv. valves from ddp 20 HP more than 191s. the truck idles kinda rough but she will smoke and go great. Any thing will help.
Old 10-13-2008 | 10:52 PM
Fueling around's Avatar
Larger DVs are not user friendly.
You were not told of the consequences? If you don't like it send them back.
Old 10-14-2008 | 06:42 AM
GARLAND's Avatar
Thanks but there is a reason that they are rough. There are too many out there with no problems for me to have a problem. I don't know if 18 1/2 timming will help or slidding plate 3/4 forward still looking and trying. THANKS
Old 10-14-2008 | 10:37 AM
Is it just the rough idle you question?
Which injectors do you have? Which pump?
Actually, fill in your signature.
Old 10-14-2008 | 11:51 AM
GARLAND's Avatar
Yes just rough idle did'nt have it until i installed delv. valves. Slid my plate 3/4 forward and adj. star wheel still rough idle but more responsive. truck runs great except at idle.
Old 10-14-2008 | 12:12 PM
Hmm 370's are not idle friendly either. Smoke & stink come to mind.
My thought is to go back to the 191 DVs. The 94-95 pumps need bigger than stock DVs, but there is always ... too much.
Higher timing may help your idle and will increase the top end, but you loose on the bottom end.
The plate & AFC tuning probably did more for the truck than the new DVs.
-John
Old 10-14-2008 | 12:21 PM
GARLAND's Avatar
Thanks i think this weekend i will take timming up to 18 1/2* and see how she does. If it dose'nt work then i will get some 191 dv. and sell or trade the ones i bought from DDP. Hope these work though a little more power with the ones i have in now. Thank you for the ideas.
Old 10-14-2008 | 08:11 PM
GARLAND's Avatar
Went back to site these dv's are DDP-042DV and they compare them to 191's but have lower egt's and less smoke but make 20hp more than 191's. I bought them from ALIGATOR PREFORMANCE. Just some extra info.
banks twinram
05-18-2010 08:10 PM
Dave88LX
02-12-2006 10:29 PM
Haulin_in_Dixie
10-23-2005 10:04 PM
TheMoose
09-20-2003 07:44 PM
Mexstan
03-31-2003 02:37 PM
Quick Reply: Rough At Idle Delv. Valves
